Saltar al contenido principal
Sanitaire SC684 Roller Brusher and Drive Belt Replacement
  1. Sanitaire SC684 Roller Brusher and Drive Belt Replacement, Roller Brush and Belt: paso 1, imagen 1 de 1
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay vacuum on its back
  2. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: paso 2, imagen 1 de 1
    • Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Detach the two latches on either side of the vacuum by pulling outwards towards the wheels.
  3. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: paso 3, imagen 1 de 1
    • Lift off the metal plate by pulling it towards you.
  4. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: paso 4, imagen 1 de 1
    • Identify the belt and brush roller.
    • The belt is a black circle made of rubber.
    • The brush roller has bristles and is tube shaped.
  5. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: paso 5, imagen 1 de 1
    • Slide the belt off of the circular knob.
  6. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: paso 6, imagen 1 de 2 Sanitaire SC684 Roller Brusher and Drive Belt Replacement: paso 6, imagen 2 de 2
    • Pull brush roller out and detach the belt off the brush roller.
Conclusión
Caycie Pascual
Miembro Desde 09/26/12
1 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 16-58, Forte Fall 2012 Miembro de Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 2,695
