Introducción
This guide can help those that are experiencing difficulty with connecting their device to a computer via a USB cable.
Qué necesitas
Remove the battery compartment cover.
Remove the battery.
2 comentarios
Wearing gloves with a soldering iron? If you need gloves you're grabbing the wrong end... Any one who cant figure out which end is the hot one, and need to be reminded to keep the hot end off of ...anything... including skin, probably shouldnt be attempting this level of repair...
Also, no cleaning the cut off bits of the old connector? They're plainly visible in one of the photos, yet the data pins dont seem to be mentioned at all in the write-up. In fact, the only points you illustrate to touch with the iron are the stabilization tabs, not the actual data/power pins.
The better way to prepare the PCB for a new connector would be to use solder wick to clean the pads, then tin the pads on the PCB with a little glop of solder on each, the same on the connector going in so that all one has to do is hit one of the support tabs to afix it in place, make sure the data pins are aligned, tap each pin with the iron to quickly liquefy the solder fixing them in place, then finish up with the other two support tabs.
Where can you buy the replacements for the USB ?
And where can I buy replacements for the battery coils? I've been looking and I this is the exact thing I need to fix mine but I don't know what to buy the stuff. Can you give any recommendations? Any websites something affordable please.
