Saltar al contenido principal
Sandisk Sansa m230 Series mp3 player Microphone Replacement
Qué necesitas
  1. Sandisk Sansa m230 Series mp3 player Microphone Replacement, Sandisk Sansa m230 Series mp3 player Teardown: paso 1, imagen 1 de 1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 2, imagen 1 de 1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 3, imagen 1 de 1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 4, imagen 1 de 1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 5, imagen 1 de 1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 6, imagen 1 de 1
    • You now have access to all components found on the inside of the device!
  7. Sandisk Sansa m230 Series mp3 player Microphone Replacement, Microphone: paso 7, imagen 1 de 1
    • Locate microphone on motherboard.
  8. Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 8, imagen 1 de 1
    • Find where microphone is connected to motherboard via solder.
  9. Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 9, imagen 1 de 2 Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 9, imagen 2 de 2
    • Use the soldering iron to liquefy the solder connecting the microphone to the motherboard.
  10. Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 10, imagen 1 de 1
    • The solder and soldering iron will be very hot at this time. Do not touch unless wearing protective gloves as you will be burnt.
    • When not in use, be sure to always elevate the hot end of the soldering iron on a metal stand to prevent incidental burns.
  11. Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 11, imagen 1 de 2 Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 11, imagen 2 de 2
    • Remove the faulty microphone as you heat and melt the soldering points.
  12. Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 12, imagen 1 de 1
    • Replace the faulty microphone with a new one in working order.
  13. Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 13, imagen 1 de 2 Sandisk Sansa m230 Series mp3 player Microphone Replacement: paso 13, imagen 2 de 2
    • With the new microphone in place, use the soldering iron and solder to create a stable connection between the motherboard and microphone.
    • Give the new solder time to cool and harden.
Conclusión
James Thorne
Miembro Desde 11/05/13
638 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Miembro de UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 480
