Saltar al contenido principal
SanDisk Wireless Stick 16 GB Disassembly
Qué necesitas
  1. SanDisk Wireless Stick 16 GB Disassembly, Presentation: paso 1, imagen 1 de 1
    • This is a 16Gb SanDisk Wireless Stick key for use in a traditional USB flash drive and content sharing via Wifi.
  2. SanDisk Wireless Stick 16 GB Disassembly, Remove plastic cover: paso 2, imagen 1 de 3 SanDisk Wireless Stick 16 GB Disassembly, Remove plastic cover: paso 2, imagen 2 de 3 SanDisk Wireless Stick 16 GB Disassembly, Remove plastic cover: paso 2, imagen 3 de 3
    • Remove the plastic around the USB port by unclipping it.
    • Then remove the plastic covering the key (also clipped on).
    • You will now be able to remove the electronic card from the lower plastic.
    • Be careful: Avoid pressing the side button when handling to avoid turning on the WiFi.
  3. SanDisk Wireless Stick 16 GB Disassembly, Lift the metal adhesive: paso 3, imagen 1 de 1
    • Peel off the metal adhesive starting from one side.
    • The SD card, which serves as an internal memory, is now visible.
    • On the left side of the picture you can see the WiFi AirStash module (metal plate).
  4. SanDisk Wireless Stick 16 GB Disassembly, Remove the SD card: paso 4, imagen 1 de 1
    • Use a plastic tool to push the SD card towards the USB port (using the offset on the side of the card).
    • Once shifted to the maximum, you can then take out the SD card by lifting the side opposite to the USB port.
Conclusión
To reassemble your device, follow the instructions of this guide in reverse order.
6 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Louis Perez
Miembro Desde 04/12/17
281 Reputación
1 Guía escrita
5 comentarios
I replaced the microsd with a faster one with a hope to get a faster transfer speed and found out that the device wont boot properly after replacing the card with the same capacity, same file system(FAT32) card.
I got it working properly by copying a whole disk image from the original card and burning it to the new card.
Maybe there is a invisible file inside the card that tells the device whether the card is genuine or not.
yusuke kikuchi - Contestar
please could you share your disk image file because i formated my card by accident and now it wont read write or even boot
Mohamed Hesham -
Which app did you used to copy the sd card image? Can you also upgrade from 16GB to like 200GB? Seems there are 2 different firmware files on Sandisk site.
makaiandras84 - Contestar
Alex H - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 51
Todo El Tiempo: 6,849
