Saltar al contenido principal
SanDisk Sansa C250 Rear Case Cover Replacement
Qué necesitas
  1. SanDisk Sansa C250 Rear Case Cover Replacement, Battery Cover: paso 1, imagen 1 de 1
    • Slide the back cover forward toward the top of the device with your thumb.
  2. SanDisk Sansa C250 Rear Case Cover Replacement: paso 2, imagen 1 de 1
    • The back cover is now separated from the device.
  3. SanDisk Sansa C250 Rear Case Cover Replacement, Battery: paso 3, imagen 1 de 1
    • Apply a fingernail or a plastic opening tool to the base of the battery.
  4. SanDisk Sansa C250 Rear Case Cover Replacement: paso 4, imagen 1 de 1
    • Lift up gently. The battery should come up and out.
  5. SanDisk Sansa C250 Rear Case Cover Replacement: paso 5, imagen 1 de 1
    • The battery is now removed from the device.
  6. SanDisk Sansa C250 Rear Case Cover Replacement, Rear Case Cover: paso 6, imagen 1 de 1
    • Remove the two black .265" screws at the base of the device.
  7. SanDisk Sansa C250 Rear Case Cover Replacement: paso 7, imagen 1 de 1
    • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  8. SanDisk Sansa C250 Rear Case Cover Replacement: paso 8, imagen 1 de 1
    • Slide the rear case cover toward the top of the device with your thumb to release it.
  9. SanDisk Sansa C250 Rear Case Cover Replacement: paso 9, imagen 1 de 1
    • The rear case cover can now be separated from the device.
Conclusión
Nicolas Coffey
Miembro Desde 01/27/12
43 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 3-30, Amido Winter 2012 Miembro de Cal Poly, Team 3-30, Amido Winter 2012
CPSU-AMIDO-W12S3G30
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 871
