Saltar al contenido principal
Samsung YP-P3 Printed Circuit Board Replacement
Qué necesitas
  1. Samsung YP-P3 Printed Circuit Board Replacement, Case Backplate: paso 1, imagen 1 de 1
    • Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
  2. Samsung YP-P3 Printed Circuit Board Replacement: paso 2, imagen 1 de 1
    • Underneath the piece of plastic you just removed, there is a small screw (Phillips #000, 2.0 mm long). Use a Phillips #000 screwdriver to remove it.
  3. Samsung YP-P3 Printed Circuit Board Replacement: paso 3, imagen 1 de 2 Samsung YP-P3 Printed Circuit Board Replacement: paso 3, imagen 2 de 2
    • Push on the backplate with both thumbs, sliding it towards the top of the device.
    • Once it begins to move, lift up slightly. You can then slide the backplate all the way off.
  4. Samsung YP-P3 Printed Circuit Board Replacement, Printed Circuit Board: paso 4, imagen 1 de 3 Samsung YP-P3 Printed Circuit Board Replacement, Printed Circuit Board: paso 4, imagen 2 de 3 Samsung YP-P3 Printed Circuit Board Replacement, Printed Circuit Board: paso 4, imagen 3 de 3
    • Before removing the circuit board, we must remove the ribbon-like wires attached to two sides of the circuit board.
    • There are two screws (Phillips #000, 2.0 mm long) holding in the circuit board. Use a Phillips #000 screwdriver to take out those screws.
  5. Samsung YP-P3 Printed Circuit Board Replacement: paso 5, imagen 1 de 2 Samsung YP-P3 Printed Circuit Board Replacement: paso 5, imagen 2 de 2
    • The battery is also attached to the circuit board by a cable. The cable is difficult to disconnect with both components in place. It's best to lift the circuit board out partially to give yourself more room to disconnect the connector.
    • The wire that is connected to the circuit board is connected by a plastic piece with two metal prongs.
    • Use the pointy end of the spudger to place in between the computer board and the plastic piece and gently pry the prongs away from the circuit board.
  6. Samsung YP-P3 Printed Circuit Board Replacement: paso 6, imagen 1 de 1
    • Disconnect the battery connector, and then lift the circuit board up.
  7. Samsung YP-P3 Printed Circuit Board Replacement: paso 7, imagen 1 de 1
    • Finally, disconnect the ribbon cable on the bottom of the circuit board. You can then lift the circuit board all the way out.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 10
Todo El Tiempo: 914
