Saltar al contenido principal
Samsung WB850F Lens Assembly Replacement
Qué necesitas
  1. Samsung WB850F Lens Assembly  Replacement, Control Panel: paso 1, imagen 1 de 3 Samsung WB850F Lens Assembly  Replacement, Control Panel: paso 1, imagen 2 de 3 Samsung WB850F Lens Assembly  Replacement, Control Panel: paso 1, imagen 3 de 3
    • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side. (HDMI port)
    • 2 screws are located on the right side of the camera. (Opposite HDMI side)
  2. Samsung WB850F Lens Assembly  Replacement: paso 2, imagen 1 de 1
    • To remove the back screen case, use the blue opening tool to open the case up from the right side.
  3. Samsung WB850F Lens Assembly  Replacement: paso 3, imagen 1 de 2 Samsung WB850F Lens Assembly  Replacement: paso 3, imagen 2 de 2
    • Use screwdriver to remove control panel screw.
    • Lift up control panel from the side where the screw was just removed.
  4. Samsung WB850F Lens Assembly  Replacement, Lens Assembly: paso 4, imagen 1 de 3 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: paso 4, imagen 2 de 3 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: paso 4, imagen 3 de 3
    • Remove the two screws.
    • Gently pry open metal case using Plastic tool openers.
  5. Samsung WB850F Lens Assembly  Replacement: paso 5, imagen 1 de 2 Samsung WB850F Lens Assembly  Replacement: paso 5, imagen 2 de 2
    • Gently pull up on the lens connector chip to remove the lens.
  6. Samsung WB850F Lens Assembly  Replacement: paso 6, imagen 1 de 1
    • Insert the new lens to be replaced. Make sure you do not get this tab caught while inserting new lens.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 12-4, Eyestone Spring 2016 Miembro de USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
4 Miembros
8 Guías creadas
2 comentarios
hi I have problem...could you please help me with my camera samsung wb850f
merdaneliyev - Contestar
I am forward to hearing from you....
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,397
