Saltar al contenido principal
Samsung WB850F Control Panel Replacement
Qué necesitas
  1. Samsung WB850F Control Panel Replacement, Control Panel: paso 1, imagen 1 de 3 Samsung WB850F Control Panel Replacement, Control Panel: paso 1, imagen 2 de 3 Samsung WB850F Control Panel Replacement, Control Panel: paso 1, imagen 3 de 3
    • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side. (HDMI port)
    • 2 screws are located on the right side of the camera. (Opposite HDMI side)
  2. Samsung WB850F Control Panel Replacement: paso 2, imagen 1 de 1
    • To remove the back screen case, use the blue opening tool to open the case up from the right side.
  3. Samsung WB850F Control Panel Replacement: paso 3, imagen 1 de 2 Samsung WB850F Control Panel Replacement: paso 3, imagen 2 de 2
    • Use screwdriver to remove control panel screw.
    • Lift up control panel from the side where the screw was just removed.
Conclusión
Equipo
USF Tampa, Team 12-4, Eyestone Spring 2016 Miembro de USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
4 Miembros
8 Guías creadas
Un comentario
Only problem .. Where can I buy a replacement control panel.
D Traynor - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 706
