Saltar al contenido principal
Samsung WB350F Rear Case Replacement
Qué necesitas
  1. Samsung WB350F Rear Case Replacement, Rear Case: paso 1, imagen 1 de 3 Samsung WB350F Rear Case Replacement, Rear Case: paso 1, imagen 2 de 3 Samsung WB350F Rear Case Replacement, Rear Case: paso 1, imagen 3 de 3
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Rear Case Replacement: paso 2, imagen 1 de 3 Samsung WB350F Rear Case Replacement: paso 2, imagen 2 de 3 Samsung WB350F Rear Case Replacement: paso 2, imagen 3 de 3
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Rear Case Replacement: paso 3, imagen 1 de 3 Samsung WB350F Rear Case Replacement: paso 3, imagen 2 de 3 Samsung WB350F Rear Case Replacement: paso 3, imagen 3 de 3
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Rear Case Replacement: paso 4, imagen 1 de 1
    • Remove the plastic casing, exposing the inner workings of the camera.
Conclusión
Zachary Bourgault
Miembro Desde 03/04/16
101 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 695
