Saltar al contenido principal
Samsung WB350F Battery Replacement
  1. Samsung WB350F Battery Replacement, Battery: paso 1, imagen 1 de 3 Samsung WB350F Battery Replacement, Battery: paso 1, imagen 2 de 3 Samsung WB350F Battery Replacement, Battery: paso 1, imagen 3 de 3
    • The first step in replacing the battery is to locate battery compartment. This compartment can be found on the underside of camera.
    • To open this compartment, slide the latch to the left.
  2. Samsung WB350F Battery Replacement: paso 2, imagen 1 de 1
    • Depress the battery's retaining clip and remove the old battery.
    • Replace the old battery with a new battery.
Conclusión
Taylor Joubert
Miembro Desde 03/04/16
273 Reputación
2 Guías creadas
Equipo
Un comentario
Does anyone know where to get the battery terminal slide piece. My-Ex wife broke it so that when you slide the part which I don't even know how to do this on purpose!! (at least no without breaking the casing)
danieltbortolini - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 1,850
