Saltar al contenido principal
Samsung WB150F Memory Card Replacement
  1. Samsung WB150F Memory Card Replacement, Memory Card: paso 1, imagen 1 de 1
    • Flip the camera upside-down so that the compartment with the battery and memory card is facing you.
  2. Samsung WB150F Memory Card Replacement: paso 2, imagen 1 de 2 Samsung WB150F Memory Card Replacement: paso 2, imagen 2 de 2
    • Using your finger, slide the plastic lock-tab to the left.
    • The compartment should swing open.
  3. Samsung WB150F Memory Card Replacement: paso 3, imagen 1 de 1
    • The larger cavity is for the battery.
    • The small thin cavity is where the memory card goes.
    • Press lightly on the memory card to eject it from the camera.
Conclusión
2 personas más completaron esta guía.
Equipo
2 comentarios
Will a micro cd n an adapter fit n the camera?
Maria Elena Will - Contestar
I was looking for max size compatability. Most folks already know how to remove and install it.
bob kavanaugh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 27
Todo El Tiempo: 843
