Saltar al contenido principal
Samsung WB150F Flash Assembly Replacement
Qué necesitas
  1. Samsung WB150F Flash Assembly Replacement, Battery: paso 1, imagen 1 de 1
    • The location of the battery compartment can be found on the underside of the camera.
  2. Samsung WB150F Flash Assembly Replacement: paso 2, imagen 1 de 2 Samsung WB150F Flash Assembly Replacement: paso 2, imagen 2 de 2
    • Have the lens of the camera face you. To open the battery compartment, slide the battery door lock towards the left. At the same time allow the battery door to swing open.
  3. Samsung WB150F Flash Assembly Replacement, LCD Screen: paso 3, imagen 1 de 1
    • Gather a PHO Phillips head screwdriver and a plastic wedge. If you do not have a plastic wedge like the one pictured, a credit card or a guitar pick can be used.
  4. Samsung WB150F Flash Assembly Replacement: paso 4, imagen 1 de 3 Samsung WB150F Flash Assembly Replacement: paso 4, imagen 2 de 3 Samsung WB150F Flash Assembly Replacement: paso 4, imagen 3 de 3
    • Take off the front casing by using your screwdriver to unscrew the screws circled in each of the photos (5 total).
    • The front casing can now be pulled from the camera.
  5. Samsung WB150F Flash Assembly Replacement: paso 5, imagen 1 de 1
    • Your camera should now look like the camera in the photo.
  6. Samsung WB150F Flash Assembly Replacement: paso 6, imagen 1 de 2 Samsung WB150F Flash Assembly Replacement: paso 6, imagen 2 de 2
    • Flip the camera over and pry the back shell of the camera off with the plastic opening tool (or credit card or guitar pick). The screen-side of your camera should now resemble the camera in the second photo.
    • Note: removing the back shell does not require removing anymore screws, it should just snap off.
  7. Samsung WB150F Flash Assembly Replacement: paso 7, imagen 1 de 3 Samsung WB150F Flash Assembly Replacement: paso 7, imagen 2 de 3 Samsung WB150F Flash Assembly Replacement: paso 7, imagen 3 de 3
    • On the screen side, remove the button circuit board (outlined in red) from the camera by using the plug located in the upper right corner of the screen side.
  8. Samsung WB150F Flash Assembly Replacement: paso 8, imagen 1 de 3 Samsung WB150F Flash Assembly Replacement: paso 8, imagen 2 de 3 Samsung WB150F Flash Assembly Replacement: paso 8, imagen 3 de 3
    • Remove the metal casing by lifting up the old screen and unscrewing the 5 screws circled in the first photo.
    • The LCD screen has a ribbon going to the main circuit board, as shown in the second photo, that needs to be detached.
    • Your camera should now resemble the third photo.
  9. Samsung WB150F Flash Assembly Replacement, Flash Assembly: paso 9, imagen 1 de 1
    • Begin removing the flash assembly by unclipping the two clips located at the top of the front housing.
  10. Samsung WB150F Flash Assembly Replacement: paso 10, imagen 1 de 1
    • Remove the remaining two clips from the top of the flash assembly located at the rear of the camera housing.
  11. Samsung WB150F Flash Assembly Replacement: paso 11, imagen 1 de 1
    • Remove the ribbon for the flash housing from the motherboard.
  12. Samsung WB150F Flash Assembly Replacement: paso 12, imagen 1 de 1
    • Remove the flash housing from the camera housing.
Conclusión
Wyatt Turner
Miembro Desde 04/12/22
265 Reputación
3 Guías creadas
Equipo
IUPUI, Team 7-7, Beck Spring 2022 Miembro de IUPUI, Team 7-7, Beck Spring 2022
IUPUI-BECK-S22S7G7
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 189
