Saltar al contenido principal
Samsung WB1100F LCD Screen Replacement
Qué necesitas
  1. Samsung WB1100F LCD Screen Replacement, LCD Screen Cover: paso 1, imagen 1 de 2 Samsung WB1100F LCD Screen Replacement, LCD Screen Cover: paso 1, imagen 2 de 2
    • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
    • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
  2. Samsung WB1100F LCD Screen Replacement: paso 2, imagen 1 de 2 Samsung WB1100F LCD Screen Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool or spudger if available.
    • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
  3. Samsung WB1100F LCD Screen Replacement, LCD Screen: paso 3, imagen 1 de 2 Samsung WB1100F LCD Screen Replacement, LCD Screen: paso 3, imagen 2 de 2
    • Remove four 1.2 mm Phillips #1 screws connected to the LCD screen.
  4. Samsung WB1100F LCD Screen Replacement: paso 4, imagen 1 de 3 Samsung WB1100F LCD Screen Replacement: paso 4, imagen 2 de 3 Samsung WB1100F LCD Screen Replacement: paso 4, imagen 3 de 3
    • Flip the LCD screen over to reveal the display cable.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap on the display cable ZIF connector.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Using a pair of tweezers, remove the ribbon cable from its socket on the motherboard.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
Conclusión
Una persona más ha completado esta guía.
Jesse Lindsey
Miembro Desde 05/13/16
581 Reputación
5 Guías creadas
Equipo
Metro State, Team 1-1, Carpenter SU 2016 Miembro de Metro State, Team 1-1, Carpenter SU 2016
MSU-CARPENTER-SU16S1G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 387
