Saltar al contenido principal
Samsung UBD-M8500 Wi-Fi Module Replacement
Qué necesitas
  1. Samsung UBD-M8500 Wi-Fi Module Replacement, Outer Shell: paso 1, imagen 1 de 1
    • On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
  2. Samsung UBD-M8500 Wi-Fi Module Replacement: paso 2, imagen 1 de 1
    • From the back lift the case of the device upwards then forward, releasing the clips from the front.
  3. Samsung UBD-M8500 Wi-Fi Module Replacement: paso 3, imagen 1 de 1
    • Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
    • Do not pull on the wires.
  4. Samsung UBD-M8500 Wi-Fi Module Replacement: paso 4, imagen 1 de 1
    • Remove the cover of the device.
  5. Samsung UBD-M8500 Wi-Fi Module Replacement, Wi-Fi Module: paso 5, imagen 1 de 1
    • Looking at the device with the cover removed you should see a black piece with a green sticker on it, that is the Wi-Fi module.
  6. Samsung UBD-M8500 Wi-Fi Module Replacement: paso 6, imagen 1 de 3 Samsung UBD-M8500 Wi-Fi Module Replacement: paso 6, imagen 2 de 3 Samsung UBD-M8500 Wi-Fi Module Replacement: paso 6, imagen 3 de 3
    • Pull the Wi-Fi module's connector directly out of its motherboard connection.
  7. Samsung UBD-M8500 Wi-Fi Module Replacement: paso 7, imagen 1 de 3 Samsung UBD-M8500 Wi-Fi Module Replacement: paso 7, imagen 2 de 3 Samsung UBD-M8500 Wi-Fi Module Replacement: paso 7, imagen 3 de 3
    • Remove the four screws from the Wi-Fi module using the Phillips #1 screwdriver.
    • Be mindful of the two hidden screws in the gaps of the black plastic piece.
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 56
