Saltar al contenido principal
Samsung UBD-K8500 Processor Cooling Fan Replacement
Qué necesitas
  1. Samsung UBD-K8500 Processor Cooling Fan Replacement, Top Panel: paso 1, imagen 1 de 2 Samsung UBD-K8500 Processor Cooling Fan Replacement, Top Panel: paso 1, imagen 2 de 2
    • Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
  2. Samsung UBD-K8500 Processor Cooling Fan Replacement: paso 2, imagen 1 de 2 Samsung UBD-K8500 Processor Cooling Fan Replacement: paso 2, imagen 2 de 2
    • Carefully lift up the top panel.
    • There is a cables that must be disconnected before completely removing the panel.
    • Detach the cable connecting the top panel to the motherboard.
    • Take the top off and set it to the side.
  3. Samsung UBD-K8500 Processor Cooling Fan Replacement, Processor Cooling Fan: paso 3, imagen 1 de 1
    • Carefully detach the cable from the fan to the circuit board by pulling on the cable connecting the fan to the circuit board.
  4. Samsung UBD-K8500 Processor Cooling Fan Replacement: paso 4, imagen 1 de 3 Samsung UBD-K8500 Processor Cooling Fan Replacement: paso 4, imagen 2 de 3 Samsung UBD-K8500 Processor Cooling Fan Replacement: paso 4, imagen 3 de 3
    • Remove both 10 mm screws from the fan using a Phillips #0 screwdriver.
  5. Samsung UBD-K8500 Processor Cooling Fan Replacement: paso 5, imagen 1 de 3 Samsung UBD-K8500 Processor Cooling Fan Replacement: paso 5, imagen 2 de 3 Samsung UBD-K8500 Processor Cooling Fan Replacement: paso 5, imagen 3 de 3
    • Remove the fan from the Blu-ray player.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 105
