Saltar al contenido principal
Samsung UBD-K8500 Power Supply Board Replacement
Qué necesitas
  1. Samsung UBD-K8500 Power Supply Board Replacement, Top Panel: paso 1, imagen 1 de 2 Samsung UBD-K8500 Power Supply Board Replacement, Top Panel: paso 1, imagen 2 de 2
    • Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
  2. Samsung UBD-K8500 Power Supply Board Replacement: paso 2, imagen 1 de 2 Samsung UBD-K8500 Power Supply Board Replacement: paso 2, imagen 2 de 2
    • Carefully lift up the top panel.
    • There is a cables that must be disconnected before completely removing the panel.
    • Detach the cable connecting the top panel to the motherboard.
    • Take the top off and set it to the side.
  3. Samsung UBD-K8500 Power Supply Board Replacement, Power Supply Board: paso 3, imagen 1 de 2 Samsung UBD-K8500 Power Supply Board Replacement, Power Supply Board: paso 3, imagen 2 de 2
    • Using your fingers, carefully pinch the clipping part of the two connectors and gently pull them out of their sockets.
  4. Samsung UBD-K8500 Power Supply Board Replacement: paso 4, imagen 1 de 2 Samsung UBD-K8500 Power Supply Board Replacement: paso 4, imagen 2 de 2
    • Remove the four 7 mm screws from the power supply board using a Phillips #0 screwdriver.
  5. Samsung UBD-K8500 Power Supply Board Replacement: paso 5, imagen 1 de 1
    • Gently remove the power supply board.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 94
