Saltar al contenido principal
Samsung U28E510 Jog Button Replacement
Qué necesitas
  1. Samsung U28E510 Jog Button Replacement, Jog Button: paso 1, imagen 1 de 3 Samsung U28E510 Jog Button Replacement, Jog Button: paso 1, imagen 2 de 3 Samsung U28E510 Jog Button Replacement, Jog Button: paso 1, imagen 3 de 3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Jog Button Replacement: paso 2, imagen 1 de 2 Samsung U28E510 Jog Button Replacement: paso 2, imagen 2 de 2
    • Flip the monitor over so that it is facedown.
    • remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove the backing to reveal the Jog Button.
  3. Samsung U28E510 Jog Button Replacement: paso 3, imagen 1 de 1
    • Disconnect signal cable to power supply board.
    • Remove and replace jog button.
Conclusión
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around monitor.
3 personas más completaron esta guía.
Jake Ritter
Miembro Desde 01/22/18
106 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S11-G1, Banghart Winter 2018 Miembro de Cal Poly, Team S11-G1, Banghart Winter 2018
CPSU-BANGHART-W18S11G1
4 Miembros
6 Guías creadas
5 comentarios
i have a samsung u28d590d and it works just the same. simple and easy as the guide says.
joshsc2 - Contestar
Does anyone have the part number or where I can buy the new jog button?
Kyle Gulliford - Contestar
“bn96-32135b “
Gary Deon -
this is the part number i found BN96-32135B
Gary Deon - Contestar
the button on my monitor wasn't working anymore - pressing it didn't do anything. So I decided to follow this great guide. When I removed the top of the button and put it on again, I noticed that it worked again. Seems that there had been just to many dust.
Thanx for this guide!
Ralf D. Müller - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 18
Ultimos 30 días: 78
Todo El Tiempo: 6,557
