Saltar al contenido principal
Samsung TL220 Power Button Replacement
Qué necesitas
  1. Samsung TL220 Power Button Replacement, Power Button: paso 1, imagen 1 de 3 Samsung TL220 Power Button Replacement, Power Button: paso 1, imagen 2 de 3 Samsung TL220 Power Button Replacement, Power Button: paso 1, imagen 3 de 3
    • Check for debris and dust around the power button to make sure it's clean.
    • If dust is absent, then begin with unscrewing the seven outside shell 4 mm Philips screws with the Philips screw driver.
    • Now carefully pry open the back casing with the ifixit plastic opening tool.
  2. Samsung TL220 Power Button Replacement: paso 2, imagen 1 de 2 Samsung TL220 Power Button Replacement: paso 2, imagen 2 de 2
    • Now that you have the back casing off, gently remove the LCD screen from the camera.
    • Next unscrew the three 4 mm Philips screws on the back panel with the same screw driver(See image).
  3. Samsung TL220 Power Button Replacement: paso 3, imagen 1 de 2 Samsung TL220 Power Button Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Unclip the four connecters that hold down the orange copper film strips with the plastic opening tool.
    • Then carefully pull out the three film strips with the ifixit tweezers.
  4. Samsung TL220 Power Button Replacement: paso 4, imagen 1 de 1
    • Remove the 4 mm Philip screw located above the center film strip with the Philips screw driver. This will allow the top frame to come loose to take off.
  5. Samsung TL220 Power Button Replacement: paso 5, imagen 1 de 1
    • Then pull back the black claw located at the bottom right of the camera, to the right with the plastic opening tool. This holds the main plate down.
  6. Samsung TL220 Power Button Replacement: paso 6, imagen 1 de 1
    • Slowly lift with your fingers, the top frame of the camera to get to the power button.
  7. Samsung TL220 Power Button Replacement: paso 7, imagen 1 de 1
    • Replace power button with new one.
Conclusión
2 personas más completaron esta guía.
chelsa
Miembro Desde 03/03/15
358 Reputación
3 Guías creadas
Equipo
3 Tech Girls Miembro de 3 Tech Girls
Community
2 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 257
