Saltar al contenido principal
Samsung TL220 LCD Screen Replacement
Qué necesitas
  1. Samsung TL220 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    • Begin with unscrewing the seven outer screws on the camera. There is one on each corner and then three at the bottom.
  2. Samsung TL220 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Now carefully pry open the back casing with the ifixit plastic opening tool.
  3. Samsung TL220 LCD Screen Replacement: paso 3, imagen 1 de 1
    • When the back casing is off, gently move the LCD screen to the side.
    • And then remove the three inner screws to remove the inside case.
  4. Samsung TL220 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Unclip the four connectors that hold down the orange copper film strips.
    • Then carefully pull out the three film strips with the ifixit plastic opening tool.
  5. Samsung TL220 LCD Screen Replacement: paso 5, imagen 1 de 2 Samsung TL220 LCD Screen Replacement: paso 5, imagen 2 de 2
    • Remove the screw located above the center film strip. This holds the top frame in place.
  6. Samsung TL220 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Unclip the four connectors to release the film strips.
  7. Samsung TL220 LCD Screen Replacement: paso 7, imagen 1 de 1
    • Next unclamp the connector to release the film strip and then you can replace your LCD screen.
Conclusión
2 personas más completaron esta guía.
Lesley
Miembro Desde 03/03/15
170 Reputación
1 Guía escrita
Equipo
3 Tech Girls Miembro de 3 Tech Girls
Community
2 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 465
