Saltar al contenido principal
Samsung TFT Color YP-T7J Motherboard Replacement
Qué necesitas
  1. Samsung TFT Color YP-T7J Motherboard Replacement, The Back Cover: paso 1, imagen 1 de 2 Samsung TFT Color YP-T7J Motherboard Replacement, The Back Cover: paso 1, imagen 2 de 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Samsung TFT Color YP-T7J Motherboard Replacement: paso 2, imagen 1 de 2 Samsung TFT Color YP-T7J Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Samsung TFT Color YP-T7J Motherboard Replacement: paso 3, imagen 1 de 3 Samsung TFT Color YP-T7J Motherboard Replacement: paso 3, imagen 2 de 3 Samsung TFT Color YP-T7J Motherboard Replacement: paso 3, imagen 3 de 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Samsung TFT Color YP-T7J Motherboard Replacement, The Battery: paso 4, imagen 1 de 2 Samsung TFT Color YP-T7J Motherboard Replacement, The Battery: paso 4, imagen 2 de 2
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Samsung TFT Color YP-T7J Motherboard Replacement: paso 5, imagen 1 de 2 Samsung TFT Color YP-T7J Motherboard Replacement: paso 5, imagen 2 de 2
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
  6. Samsung TFT Color YP-T7J Motherboard Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 6, imagen 1 de 3 Samsung TFT Color YP-T7J Motherboard Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 6, imagen 2 de 3 Samsung TFT Color YP-T7J Motherboard Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: paso 6, imagen 3 de 3
    • Once the battery has been removed you can see the motherboard.
    • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
    • The USB connector can now be taken off of the device.
  7. Samsung TFT Color YP-T7J Motherboard Replacement, The Front Cover: paso 7, imagen 1 de 2 Samsung TFT Color YP-T7J Motherboard Replacement, The Front Cover: paso 7, imagen 2 de 2
    • Using the philips screwdriver, remove the two screws on the mother board.
  8. Samsung TFT Color YP-T7J Motherboard Replacement: paso 8, imagen 1 de 3 Samsung TFT Color YP-T7J Motherboard Replacement: paso 8, imagen 2 de 3 Samsung TFT Color YP-T7J Motherboard Replacement: paso 8, imagen 3 de 3
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  9. Samsung TFT Color YP-T7J Motherboard Replacement: paso 9, imagen 1 de 1
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  10. Samsung TFT Color YP-T7J Motherboard Replacement: paso 10, imagen 1 de 2 Samsung TFT Color YP-T7J Motherboard Replacement: paso 10, imagen 2 de 2
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
  11. Samsung TFT Color YP-T7J Motherboard Replacement, Motherboard: paso 11, imagen 1 de 2 Samsung TFT Color YP-T7J Motherboard Replacement, Motherboard: paso 11, imagen 2 de 2
    • Remove the 3 screws located around the motherboard. 2 screws are located on the left side and1 screw is located on the right side.
    • NOTE:The orientation of the second picture is screen side down!
  12. Samsung TFT Color YP-T7J Motherboard Replacement: paso 12, imagen 1 de 2 Samsung TFT Color YP-T7J Motherboard Replacement: paso 12, imagen 2 de 2
    • The motherboard should be loose from the middle casing.
    • Gently pull the motherboard away from the middle casing
    • The device should now be in multiple parts.
Conclusión
Una persona más ha completado esta guía.
Dylan Peters
Miembro Desde 10/18/13
409 Reputación
4 Guías creadas
Equipo
Clemson, Team 14-8, Benson Fall 2013 Miembro de Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 455
