Saltar al contenido principal
Samsung Star Touch Screen Replacement
Qué necesitas
Resumen del Video
  1. Samsung Star Touch Screen Replacement, Touch Screen: paso 1, imagen 1 de 3 Samsung Star Touch Screen Replacement, Touch Screen: paso 1, imagen 2 de 3 Samsung Star Touch Screen Replacement, Touch Screen: paso 1, imagen 3 de 3
    • Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws.
  2. Samsung Star Touch Screen Replacement: paso 2, imagen 1 de 3 Samsung Star Touch Screen Replacement: paso 2, imagen 2 de 3 Samsung Star Touch Screen Replacement: paso 2, imagen 3 de 3
    • After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board.
  3. Samsung Star Touch Screen Replacement: paso 3, imagen 1 de 3 Samsung Star Touch Screen Replacement: paso 3, imagen 2 de 3 Samsung Star Touch Screen Replacement: paso 3, imagen 3 de 3
    • Unstuck camera keys and remove the middle bezel.
  4. Samsung Star Touch Screen Replacement: paso 4, imagen 1 de 2 Samsung Star Touch Screen Replacement: paso 4, imagen 2 de 2
    • Disconnect the flex-cable from touch screen and the flex-cable from the small keyboard down.
  5. Samsung Star Touch Screen Replacement: paso 5, imagen 1 de 3 Samsung Star Touch Screen Replacement: paso 5, imagen 2 de 3 Samsung Star Touch Screen Replacement: paso 5, imagen 3 de 3
    • On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation.
  6. Samsung Star Touch Screen Replacement: paso 6, imagen 1 de 2 Samsung Star Touch Screen Replacement: paso 6, imagen 2 de 2
    • Now is easy to remove the touch screen.
  7. Samsung Star Touch Screen Replacement: paso 7, imagen 1 de 3 Samsung Star Touch Screen Replacement: paso 7, imagen 2 de 3 Samsung Star Touch Screen Replacement: paso 7, imagen 3 de 3
    • Install new touch screen and assembly the phone.
Conclusión
10 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,470 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,482 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 3,845
