Saltar al contenido principal
Samsung Solstice Battery Replacement
Qué necesitas
  1. Samsung Solstice Battery Replacement, Removing the back cover: paso 1, imagen 1 de 3 Samsung Solstice Battery Replacement, Removing the back cover: paso 1, imagen 2 de 3 Samsung Solstice Battery Replacement, Removing the back cover: paso 1, imagen 3 de 3
    • Gently slide the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
    • Set the cover off to the side once you have removed it.
  2. Samsung Solstice Battery Replacement, Removing the battery: paso 2, imagen 1 de 3 Samsung Solstice Battery Replacement, Removing the battery: paso 2, imagen 2 de 3 Samsung Solstice Battery Replacement, Removing the battery: paso 2, imagen 3 de 3
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool in between the rear end of the battery and the plastic frame.
    • Pry the battery up out of its recess and away from the phone.
Conclusión
Colton Glyder
Miembro Desde 09/05/14
301 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 356
