Saltar al contenido principal
Samsung SmartCam HD Speaker Replacement
Qué necesitas
  1. Samsung SmartCam HD Speaker Replacement, Speaker: paso 1, imagen 1 de 3 Samsung SmartCam HD Speaker Replacement, Speaker: paso 1, imagen 2 de 3 Samsung SmartCam HD Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Remove the mount.
    • Use the mount replacement guide if necessary to take the mount off.
  2. Samsung SmartCam HD Speaker Replacement: paso 2, imagen 1 de 2 Samsung SmartCam HD Speaker Replacement: paso 2, imagen 2 de 2
    • Unscrew the screw next to the mount holder.
  3. Samsung SmartCam HD Speaker Replacement: paso 3, imagen 1 de 3 Samsung SmartCam HD Speaker Replacement: paso 3, imagen 2 de 3 Samsung SmartCam HD Speaker Replacement: paso 3, imagen 3 de 3
    • At the bottom of the SmartCam there is a tab that you can stick a spudger r in.
    • Once the spudger is in, gently pry it open.
    • Work your way around the SmartCam with the spudger loosing 8 clips.
    • Buttons may fall out, but can be reinserted easily.
  4. Samsung SmartCam HD Speaker Replacement: paso 4, imagen 1 de 2 Samsung SmartCam HD Speaker Replacement: paso 4, imagen 2 de 2
    • Gently remover the cover.
    • Beware of the wires connected to the camera.
  5. Samsung SmartCam HD Speaker Replacement: paso 5, imagen 1 de 3 Samsung SmartCam HD Speaker Replacement: paso 5, imagen 2 de 3 Samsung SmartCam HD Speaker Replacement: paso 5, imagen 3 de 3
    • The speaker should be attached to the cover with red and black wires going to the main board.
    • Unscrew the two screws holding the speaker in place.
  6. Samsung SmartCam HD Speaker Replacement: paso 6, imagen 1 de 3 Samsung SmartCam HD Speaker Replacement: paso 6, imagen 2 de 3 Samsung SmartCam HD Speaker Replacement: paso 6, imagen 3 de 3
    • Gently take the speaker out of the cover.
    • Take out the red and black wires from a small plug-in on the main board.
Conclusión
2 personas más completaron esta guía.
Pranab Baidya
Miembro Desde 06/27/17
104 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team S1-G1, Liner Summer 2017 Miembro de UW Tacoma, Team S1-G1, Liner Summer 2017
UWT-LINER-SU17S1G1
4 Miembros
6 Guías creadas
Un comentario
You mind giving speaker part number. I have the Samsung camera with the smaller speaker. Any ideas
frank scalise - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 579
