Introducción
The WiFi card enables you to access the internet wirelessly and on-the-go, instead of being connected to an Ethernet cable. If your WiFi card is broken or malfunctioning, it will need to be replaced.
Qué necesitas
Use the screwdriver to remove the ten 2.5mm Phillips #00 screws.
Remove the back panel of the laptop.
Una persona más ha completado esta guía.
