Saltar al contenido principal
Samsung Series 9 NP900X4B-A02 Speaker Replacement
Qué necesitas
  1. Samsung Series 9 NP900X4B-A02 Speaker Replacement, Battery: paso 1, imagen 1 de 2 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung Series 9 NP900X4B-A02 Speaker Replacement: paso 2, imagen 1 de 1
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung Series 9 NP900X4B-A02 Speaker Replacement: paso 3, imagen 1 de 2 Samsung Series 9 NP900X4B-A02 Speaker Replacement: paso 3, imagen 2 de 2
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung Series 9 NP900X4B-A02 Speaker Replacement: paso 4, imagen 1 de 1
    • Lift and pull out the battery.
  5. Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: paso 5, imagen 1 de 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: paso 5, imagen 2 de 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement, Speaker: paso 5, imagen 3 de 3
    • Unplug the left speaker's cable from the motherboard.
    • Lift up and remove the left speaker.
  6. Samsung Series 9 NP900X4B-A02 Speaker Replacement: paso 6, imagen 1 de 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement: paso 6, imagen 2 de 3 Samsung Series 9 NP900X4B-A02 Speaker Replacement: paso 6, imagen 3 de 3
    • Unplug the right speaker's cable from the motherboard.
    • Lift up and remove the right speaker.
Conclusión
Brady Hildreth
Miembro Desde 11/04/19
361 Reputación
3 Guías creadas
Equipo
IUPUI, Team S1-G4, Henning Fall 2019 Miembro de IUPUI, Team S1-G4, Henning Fall 2019
IUPUI-HENNING-F19S1G4
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 18
Todo El Tiempo: 649
