Introducción
Following this guide will ensure a safe and easy way to replace the Input/Output Printed Circuit Board (I/O PCB) in your Samsung Series 9 (NP900X4B-A02) laptop. No other skills are required to to replace this board, which means anyone can accomplish this task.
The I/O PCB is the board that controls most of the interaction between a person and their computer. As with other circuit boards, a problem with your I/O PCB can be difficult to diagnose. Before replacing your I/O PCB, be sure that the board is the cause of the issue.
Before beginning this guide, ensure that your laptop is powered off and disconnected from its power source.
Qué necesitas
Remove the ten screws along the base using a Phillips #000.
Use a Plastic Opening Tool to pry open the base .
Unplug the left speaker's cable from the motherboard.
Lift up and remove the left speaker.
Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
