Introducción
If you are encountering issues such as unreadable memory card followed by a notification like “this card cannot be used” or card running slower than anticipated, these issues may constitute replacing the card.
Qué necesitas
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
Locate the AUX and USB port on the left side of the laptop.
Using your Phillips #0 Screwdriver, unscrew the 0.1mm screws securing the memory card in place at the top.
2 personas más completaron esta guía.
