Introducción
If your computer is no longer holding a charge or is dying quickly without a charger, then you should replace the battery. This guide will help you replace the battery.
Qué necesitas
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
Remove the last three remaining 0.1mm screws attached to the battery.
Una persona más ha completado esta guía.
