Saltar al contenido principal
Samsung Series 9 NP900X3A Back Panel Replacement
Qué necesitas
  1. Samsung Series 9 NP900X3A Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A Back Panel Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A Back Panel Replacement: paso 3, imagen 1 de 3 Samsung Series 9 NP900X3A Back Panel Replacement: paso 3, imagen 2 de 3 Samsung Series 9 NP900X3A Back Panel Replacement: paso 3, imagen 3 de 3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 1,099
