Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Series 7XE700T1A Volume Button Replacement
Qué necesitas
    1. Samsung Series 7XE700T1A Volume Button Replacement, Back panel: paso 1, imagen 1 de 1
      • Remove the microSD card before attempting to open the device. Wedge the opening tools inside the device and move it around the perimeter (between the black and silver panels, not between the glass and the black panel) until you have loosened the adhesive that is keeping it together.
      Pregunta a FixBot
      Agregar Comentario
    2. Samsung Series 7XE700T1A Volume Button Replacement: paso 2, imagen 1 de 2 Samsung Series 7XE700T1A Volume Button Replacement: paso 2, imagen 2 de 2
      • With your hands, open up the back panel, separating it from the tablet.
      Pregunta a FixBot
      Agregar Comentario
    1. Samsung Series 7XE700T1A Volume Button Replacement, Volume Button: paso 3, imagen 1 de 1
      • Now that the back panel has been removed, using your fingers, push out the volume button from the inside.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 33
Todo El Tiempo: 742
