Saltar al contenido principal
Samsung Series 5 Ultrabook Speakers Replacement
Qué necesitas
  1. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Screws on the Back Cover: paso 1, imagen 1 de 2 Samsung Series 5 Ultrabook Speakers Replacement, Remove the Screws on the Back Cover: paso 1, imagen 2 de 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Rubber Pads: paso 2, imagen 1 de 2 Samsung Series 5 Ultrabook Speakers Replacement, Remove the Rubber Pads: paso 2, imagen 2 de 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Back Cover: paso 3, imagen 1 de 2 Samsung Series 5 Ultrabook Speakers Replacement, Remove the Back Cover: paso 3, imagen 2 de 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 Ultrabook Speakers Replacement: paso 4, imagen 1 de 2 Samsung Series 5 Ultrabook Speakers Replacement: paso 4, imagen 2 de 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 Ultrabook Speakers Replacement: paso 5, imagen 1 de 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Battery: paso 6, imagen 1 de 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 Ultrabook Speakers Replacement: paso 7, imagen 1 de 1
    • Remove the battery from the laptop.
Conclusión
Javier Jimenez
Miembro Desde 11/04/19
223 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G6, Harley Fall 2019 Miembro de IUPUI, Team S1-G6, Harley Fall 2019
IUPUI-HARLEY-F19S1G6
3 Miembros
2 Guías creadas
Un comentario
And about removing speakers?
Rodrigo Melo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 742
