Saltar al contenido principal
Samsung Series 5 UltraTouch Battery Replacement
Qué necesitas
  1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: paso 1, imagen 1 de 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: paso 1, imagen 2 de 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: paso 2, imagen 1 de 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: paso 2, imagen 2 de 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: paso 3, imagen 1 de 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: paso 3, imagen 2 de 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 UltraTouch Battery Replacement: paso 4, imagen 1 de 2 Samsung Series 5 UltraTouch Battery Replacement: paso 4, imagen 2 de 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 UltraTouch Battery Replacement: paso 5, imagen 1 de 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: paso 6, imagen 1 de 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 UltraTouch Battery Replacement: paso 7, imagen 1 de 1
    • Remove the battery from the laptop.
Conclusión
14 personas más completaron esta guía.
Timothy
Miembro Desde 01/30/15
1,579 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 16-3, Watkins Winter 2015 Miembro de USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
4 Miembros
5 Guías creadas
2 comentarios
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - Contestar
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 45
Todo El Tiempo: 26,768
