Saltar al contenido principal
Samsung Series 5 3G Chromebook Battery Replacement
Qué necesitas
  1. Samsung Series 5 3G Chromebook Battery Replacement, Back Cover: paso 1, imagen 1 de 2 Samsung Series 5 3G Chromebook Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel using your fingernails.
    • Remove all the seven screws from the bottom panel.
  2. Samsung Series 5 3G Chromebook Battery Replacement: paso 2, imagen 1 de 2 Samsung Series 5 3G Chromebook Battery Replacement: paso 2, imagen 2 de 2
    • Loosen the back cover panel using a spudger.
  3. Samsung Series 5 3G Chromebook Battery Replacement: paso 3, imagen 1 de 2 Samsung Series 5 3G Chromebook Battery Replacement: paso 3, imagen 2 de 2
    • Once you work your way around, you can remove the panel.
  4. Samsung Series 5 3G Chromebook Battery Replacement, Battery: paso 4, imagen 1 de 3 Samsung Series 5 3G Chromebook Battery Replacement, Battery: paso 4, imagen 2 de 3 Samsung Series 5 3G Chromebook Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Remove three Phillips screws from the battery.
    • Disconnect the battery from the motherboard.
    • Lift the battery up and away from the laptop to remove it.
Conclusión
11 personas más completaron esta guía.
Un comentario
i want the chromebook battery
Christopher Jorgensen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 12
Todo El Tiempo: 19,208
