Saltar al contenido principal
Samsung Series 5 3G Chromebook Back Cover Replacement
Qué necesitas
  1. Samsung Series 5 3G Chromebook Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 Samsung Series 5 3G Chromebook Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel using your fingernails.
    • Remove all the seven screws from the bottom panel.
  2. Samsung Series 5 3G Chromebook Back Cover Replacement: paso 2, imagen 1 de 2 Samsung Series 5 3G Chromebook Back Cover Replacement: paso 2, imagen 2 de 2
    • Loosen the back cover panel using a spudger.
  3. Samsung Series 5 3G Chromebook Back Cover Replacement: paso 3, imagen 1 de 2 Samsung Series 5 3G Chromebook Back Cover Replacement: paso 3, imagen 2 de 2
    • Once you work your way around, you can remove the panel.
Conclusión
3 personas más completaron esta guía.
Un comentario
If anyone was wondering about putting the shampoo in the same bag as your Chromebook…don't! I'm just going from the house to the man cave (maybe 100 feet). A couple hours later I remember charge the chrome…and F
Chris Goh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 20
Todo El Tiempo: 13,416
