Saltar al contenido principal
Samsung Series 3 NP300E5A-A02UB Panel Replacement
Qué necesitas
  1. Samsung Series 3 NP300E5A-A02UB Panel Replacement, Battery: paso 1, imagen 1 de 1
    • Place the computer upside down, with the battery pack facing away from you.
  2. Samsung Series 3 NP300E5A-A02UB Panel Replacement: paso 2, imagen 1 de 2 Samsung Series 3 NP300E5A-A02UB Panel Replacement: paso 2, imagen 2 de 2
    • Remove the battery by pushing out the locks on either end then pushing the battery away from you.
  3. Samsung Series 3 NP300E5A-A02UB Panel Replacement, Panel: paso 3, imagen 1 de 1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
  4. Samsung Series 3 NP300E5A-A02UB Panel Replacement: paso 4, imagen 1 de 2 Samsung Series 3 NP300E5A-A02UB Panel Replacement: paso 4, imagen 2 de 2
    • Pull the panel towards you to release it, then lift it off the computer.
  5. Samsung Series 3 NP300E5A-A02UB Panel Replacement: paso 5, imagen 1 de 1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw next to the label “ODD."
    • Remove the three 4.5mm screws from around the memory drive nest.
  6. Samsung Series 3 NP300E5A-A02UB Panel Replacement: paso 6, imagen 1 de 1
    • Using the J1 Japanese Industrial Standard screwdriver, remove the thirteen 9.5mm screws from the panel that cover the bottom of the computer.
  7. Samsung Series 3 NP300E5A-A02UB Panel Replacement: paso 7, imagen 1 de 3 Samsung Series 3 NP300E5A-A02UB Panel Replacement: paso 7, imagen 2 de 3 Samsung Series 3 NP300E5A-A02UB Panel Replacement: paso 7, imagen 3 de 3
    • Begin removing the computer casing by prying beside the disk drive with the iFixit opening tool and the spudger, working counterclockwise.
    • Lift the panel from the computer.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 526
