Introducción
Replacing the power jack is an involved process. In order to reach this part it is necessary to remove several laptop hardware components. Follow the steps of this guide in order to complete the project.
Qué necesitas
Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
Using the J0 Japanese Industrial Standard screwdriver, remove the two 7mm screws that hold down the plug-in to the disc drive.
Locate the power jack on the corner of the motherboard.
Locate the four connectors that hold the power jack to the motherboard.
After soldering the new power jack in place, reassemble your device by following these instructions in reverse order.
3 personas más completaron esta guía.
