Saltar al contenido principal
Samsung ST76 Motherboard Replacement
Qué necesitas
  1. Samsung ST76 Motherboard Replacement, Back Panel: paso 1, imagen 1 de 3 Samsung ST76 Motherboard Replacement, Back Panel: paso 1, imagen 2 de 3 Samsung ST76 Motherboard Replacement, Back Panel: paso 1, imagen 3 de 3
    • Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
    • Do not mix the 5 screws; they are different sizes.
  2. Samsung ST76 Motherboard Replacement: paso 2, imagen 1 de 2 Samsung ST76 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use your fingers to pull the back cover off.
  3. Samsung ST76 Motherboard Replacement, Screen: paso 3, imagen 1 de 2 Samsung ST76 Motherboard Replacement, Screen: paso 3, imagen 2 de 2
    • Separate the button panel to reveal the port holding the screen on.
    • Use a plastic opening tool to help with this task.
  4. Samsung ST76 Motherboard Replacement: paso 4, imagen 1 de 2 Samsung ST76 Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the yellow cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
  5. Samsung ST76 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 3 Samsung ST76 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 3 Samsung ST76 Motherboard Replacement, Motherboard: paso 5, imagen 3 de 3
    • Remove 2 3mm screws from the metal plate covering the motherboard and lens using a Phillips #00 screw driver.
  6. Samsung ST76 Motherboard Replacement: paso 6, imagen 1 de 3 Samsung ST76 Motherboard Replacement: paso 6, imagen 2 de 3 Samsung ST76 Motherboard Replacement: paso 6, imagen 3 de 3
    • Remove the 4 cables connecting the motherboard to the camera body.
Conclusión
2 personas más completaron esta guía.
Jessica Bain
Miembro Desde 03/11/15
393 Reputación
2 Guías creadas
Equipo
Marist, Team 1-6, Laflen Spring 2015 Miembro de Marist, Team 1-6, Laflen Spring 2015
MARS-LAFLEN-S15S1G6
2 Miembros
8 Guías creadas
3 comentarios
Thanks for great info. I should add that one can also clean the sensor. Sensor is circular plate with 3 screws at back of the lens. Now the camera is like new!
compand - Contestar
Where can you buy a replacement motherboard?
Demaree Wiitala - Contestar
ST76 and ST77 are very close relatives.
As it can be seen on the parts, some are marked: ”ST77”
Paul
Paul Cohen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 864
