Saltar al contenido principal
Samsung ST150F Rear Panel Control Board Replacement
Qué necesitas
  1. Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: paso 1, imagen 1 de 3 Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: paso 1, imagen 2 de 3 Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: paso 1, imagen 3 de 3
    • Remove these screws from the camera using a phillips head screwdriver.
  2. Samsung ST150F Rear Panel Control Board Replacement: paso 2, imagen 1 de 1
    • Lay the camera down on the table and remove the metal shell from the front.
  3. Samsung ST150F Rear Panel Control Board Replacement: paso 3, imagen 1 de 1
    • Wedge a spudger/flathead screwdriver inside of the shell where the screws were to pry the shell off of the back.
  4. Samsung ST150F Rear Panel Control Board Replacement: paso 4, imagen 1 de 1
    • Remove the shell the from the back of the camera.
  5. Samsung ST150F Rear Panel Control Board Replacement, Rear Panel Control Board: paso 5, imagen 1 de 1
    • Remove the Phillips head screw from the rear panel control board to reveal the LCD's connection to the motherboard.
  6. Samsung ST150F Rear Panel Control Board Replacement: paso 6, imagen 1 de 3 Samsung ST150F Rear Panel Control Board Replacement: paso 6, imagen 2 de 3 Samsung ST150F Rear Panel Control Board Replacement: paso 6, imagen 3 de 3
    • Remove the Phillips head screws from the metal back plate.
  7. Samsung ST150F Rear Panel Control Board Replacement: paso 7, imagen 1 de 1
    • Use the spudger to life the tab on the side of the metal plate.
  8. Samsung ST150F Rear Panel Control Board Replacement: paso 8, imagen 1 de 2 Samsung ST150F Rear Panel Control Board Replacement: paso 8, imagen 2 de 2
    • Pull gently on the control panel to remove it from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Matthew Eaton
Miembro Desde 03/29/15
107 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 13
Todo El Tiempo: 666
