Saltar al contenido principal
Samsung ST150F LCD Screen Replacement
Qué necesitas
  1. Samsung ST150F LCD Screen Replacement, Outer Casing: paso 1, imagen 1 de 3 Samsung ST150F LCD Screen Replacement, Outer Casing: paso 1, imagen 2 de 3 Samsung ST150F LCD Screen Replacement, Outer Casing: paso 1, imagen 3 de 3
    • Remove these screws from the camera using a phillips head screwdriver.
  2. Samsung ST150F LCD Screen Replacement: paso 2, imagen 1 de 1
    • Lay the camera down on the table and remove the metal shell from the front.
  3. Samsung ST150F LCD Screen Replacement: paso 3, imagen 1 de 1
    • Wedge a spudger/flathead screwdriver inside of the shell where the screws were to pry the shell off of the back.
  4. Samsung ST150F LCD Screen Replacement: paso 4, imagen 1 de 1
    • Remove the shell the from the back of the camera.
  5. Samsung ST150F LCD Screen Replacement, LCD Screen: paso 5, imagen 1 de 1
    • Remove the Phillips head screw from the rear panel control board to reveal the LCD's connection to the motherboard.
  6. Samsung ST150F LCD Screen Replacement: paso 6, imagen 1 de 1
    • Use a spudger to flip up the light gray lever(as shown in the photo). This will release the screen so that you may pull it out.
  7. Samsung ST150F LCD Screen Replacement: paso 7, imagen 1 de 1
    • Pull the screen out of the mother board.
Conclusión
4 personas más completaron esta guía.
Nicholas Pavao
Miembro Desde 03/27/15
418 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 18
Todo El Tiempo: 940
