Herramientas
Partes
No se especificaron partes.
Detach the battery cover by sliding the cover down toward the bottom of the phone.
Lift up on the battery cover to complete cover removal.
Use a phillips head (PH) #00 screwdriver to remove four screws connecting the two halves of the case.
Using your plastic opening tool, pry under the back case starting with the top as marked by red circle.
The volume button and camera button are held in by the back case. Volume button pictured. Camera button opposite.
REASSEMBLY ONLY: Replace volume and camera buttons in place. Then, insert the top of the back case FIRST and squeeze together clips as you work toward the bottom of the phone.
