Saltar al contenido principal
Samsung SPH-M360 Battery Replacement
  1. Samsung SPH-M360 Battery Replacement, Battery: paso 1, imagen 1 de 3 Samsung SPH-M360 Battery Replacement, Battery: paso 1, imagen 2 de 3 Samsung SPH-M360 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Samsung SPH-M360 Battery Replacement: paso 2, imagen 1 de 3 Samsung SPH-M360 Battery Replacement: paso 2, imagen 2 de 3 Samsung SPH-M360 Battery Replacement: paso 2, imagen 3 de 3
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
Conclusión
To reassemble your device, follow these instructions in reverse order. Be sure to place the side of the battery showing two small arrows in first, with the arrows showing and pointing towards the bottom end of the phone.
Hunter Parker
Miembro Desde 10/22/15
475 Reputación
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 208
