Introducción
Do you need to replace your motherboard? To do so, follow these steps to remove your old one and just perform them in reverse with the new motherboard to reassemble.
Qué necesitas
Once the battery pack is removed from the phone, remove the five indicated screws with a size #00 Philips screwdriver.
Bend back the antenna to access the indicated left middle screw in order to unscrew it.
Casi Terminas!
Conclusión
