Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Repair guide on how to replace a Speaker on a Samsung SPH-A500 cell phone.
  1. Flip open the phone, remove the two rubber covers under the LCD screen.
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Using an Ipod opening tool or your finger nails, pry open the back cover of the LCD screen.
    • Using an Ipod opening tool or your finger nails, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Completely separate the back cover from the rest of the phone.
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  5. The speaker is covered with silver tape on the bottom of the logic board.
    • The speaker is covered with silver tape on the bottom of the logic board.
  6. Remove the silver tape that is covering the speaker.
    • Remove the silver tape that is covering the speaker.
  7. Remove the speaker.
    • Remove the speaker.
    • Note: In order to completely remove the speaker you must disconnect the wires, which will require a soldering iron to reattach the new speaker.
  8. Attach the new speaker using a soldering iron.
    • Attach the new speaker using a soldering iron.
    • Put the speaker back to it's original position and place the silver tape over it.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 18-100, Johann Spring 2010 Miembro de Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,225
