Saltar al contenido principal
Introducción
This is a step by step guide on how to replace the Samsung SPH-A500 logic board.
Partes
No se especificaron partes.
  1. Turn phone over
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Remove the battery from the phone, which will reveal four screws at the corners of the phone.
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Remove all four screws using a small Philips screwdriver.
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. Kits de Reparación de Android
    A new screen or battery is one kit away.
    Comprar Ahora
    Comprar Ahora
  5. Remove back cover by carefully prying it open.
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  6. Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Do not completely pull out the circuit board.
  7. Look for the clip at the top right corner of the logic board.
    • Look for the clip at the top right corner of the logic board.
  8. Remove the clip from the logic board.
    • Remove the clip from the logic board.
  9. Remove the logic board.
    • Remove the logic board.
    • Replace the broken logic board with a new one.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 18-100, Johann Spring 2010 Miembro de Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,890
