Saltar al contenido principal
Introducción
Breaking down the phone to replace the LCD screen.
Partes
  1. Flip open the phone, remove the two rubber covers under the LCD screen.
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Using a plastic opening tool, pry open the back cover of the LCD screen.
    • Using a plastic opening tool, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Completely separate the back cover from the rest of the phone.
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. The LCD screen is big, rectangular screen in the center of the logic board.
    • The LCD screen is big, rectangular screen in the center of the logic board.
  6. Remove the glue and black tape that is attached to the LCD screen
    • Remove the glue and black tape that is attached to the LCD screen
  7. Remove Broken LCD Screen.
    • Remove Broken LCD Screen.
  8. Attach the New LCD Screen, with wire point up and out to the black connector.
    • Attach the New LCD Screen, with wire point up and out to the black connector.
    • Note: Super Glue may be required to permanently attach LCD to the black connector
Conclusión
Derek Panger
Miembro Desde 16/04/10
21 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 18-100, Johann Spring 2010 Miembro de Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,321
