Saltar al contenido principal
Samsung SPEX SCH-R210 Speaker Replacement
Qué necesitas
  1. Samsung SPEX SCH-R210 Speaker Replacement, Back Cover: paso 1, imagen 1 de 3 Samsung SPEX SCH-R210 Speaker Replacement, Back Cover: paso 1, imagen 2 de 3 Samsung SPEX SCH-R210 Speaker Replacement, Back Cover: paso 1, imagen 3 de 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung SPEX SCH-R210 Speaker Replacement, Battery: paso 2, imagen 1 de 1
    • Locate the access notch at the end of the battery compartment.
  3. Samsung SPEX SCH-R210 Speaker Replacement: paso 3, imagen 1 de 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
  4. Samsung SPEX SCH-R210 Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to unscrew the four 3/16" screws holding the black plastic cover of the phone in place.
  5. Samsung SPEX SCH-R210 Speaker Replacement: paso 5, imagen 1 de 2 Samsung SPEX SCH-R210 Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the small, black headphone cover from the left side of the phone by gently pulling it off.
    • Remove the small, black volume cover from the right side of the phone by gentle pulling it off.
  6. Samsung SPEX SCH-R210 Speaker Replacement: paso 6, imagen 1 de 1
    • Remove the black plastic cover from the back of the phone by slowly pulling it off. This may take a little effort.
  7. Samsung SPEX SCH-R210 Speaker Replacement: paso 7, imagen 1 de 1
    • Once the plastic cover is removed, turn the cover over so that the insides are visible.
    • Using your fingernail, pry out the small, grey, circular speaker from the cover.
  8. Samsung SPEX SCH-R210 Speaker Replacement: paso 8, imagen 1 de 1
    • Remove the old speaker, discard it and replace it with a new speaker.
Conclusión
2 personas más completaron esta guía.
Susan
Miembro Desde 07/11/13
331 Reputación
3 Guías creadas
Equipo
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Miembro de WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 56
Todo El Tiempo: 295
