Saltar al contenido principal
Samsung SPEX SCH-R210 Keypad Replacement
Qué necesitas
  1. Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: paso 1, imagen 1 de 3 Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: paso 1, imagen 2 de 3 Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: paso 1, imagen 3 de 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung SPEX SCH-R210 Keypad Replacement, Battery: paso 2, imagen 1 de 1
    • Locate the access notch at the end of the battery compartment.
  3. Samsung SPEX SCH-R210 Keypad Replacement: paso 3, imagen 1 de 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
  4. Samsung SPEX SCH-R210 Keypad Replacement, Keypad: paso 4, imagen 1 de 2 Samsung SPEX SCH-R210 Keypad Replacement, Keypad: paso 4, imagen 2 de 2
    • Remove the four 4.8 mm screws from the midframe using a Phillips #00 screwdriver.
  5. Samsung SPEX SCH-R210 Keypad Replacement: paso 5, imagen 1 de 1
    • Remove the headphone cover from the left side of the midframe.
  6. Samsung SPEX SCH-R210 Keypad Replacement: paso 6, imagen 1 de 1
    • Remove the volume cover from the right side of the midframe.
  7. Samsung SPEX SCH-R210 Keypad Replacement: paso 7, imagen 1 de 1
    • Use your hands to separate the midframe from the rest of the phone.
    • This may take a little effort to remove.
  8. Samsung SPEX SCH-R210 Keypad Replacement: paso 8, imagen 1 de 1
    • Use a 1.5 mm hex screwdriver to remove the three 2.4 mm screws around the motherboard.
  9. Samsung SPEX SCH-R210 Keypad Replacement: paso 9, imagen 1 de 1
    • Lift the metal plate off of the motherboard and set it aside.
  10. Samsung SPEX SCH-R210 Keypad Replacement: paso 10, imagen 1 de 2 Samsung SPEX SCH-R210 Keypad Replacement: paso 10, imagen 2 de 2
    • Push on the white plastic tabs and the keypad at the same time to remove the motherboard.
  11. Samsung SPEX SCH-R210 Keypad Replacement: paso 11, imagen 1 de 2 Samsung SPEX SCH-R210 Keypad Replacement: paso 11, imagen 2 de 2
    • Turn the phone over to its front side.
    • Apply pressure on the keypad.
    • The keypad will come out easily.
Conclusión
Susan
Miembro Desde 07/11/13
331 Reputación
3 Guías creadas
Equipo
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Miembro de WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 301
