Saltar al contenido principal
Samsung SGH-E317 Motherboard Replacement
Qué necesitas
  1. Samsung SGH-E317 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. Samsung SGH-E317 Motherboard Replacement, Motherboard: paso 2, imagen 1 de 1
    • Unscrew the four 4.5mm screws located on the back plate.
  3. Samsung SGH-E317 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the rubber screw cover using your fingernail.
  4. Samsung SGH-E317 Motherboard Replacement: paso 4, imagen 1 de 1
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. Samsung SGH-E317 Motherboard Replacement: paso 5, imagen 1 de 1
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. Samsung SGH-E317 Motherboard Replacement: paso 6, imagen 1 de 1
    • With the back panel removed, the motherboard should be fully exposed.
  7. Samsung SGH-E317 Motherboard Replacement: paso 7, imagen 1 de 2 Samsung SGH-E317 Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. Samsung SGH-E317 Motherboard Replacement: paso 8, imagen 1 de 2 Samsung SGH-E317 Motherboard Replacement: paso 8, imagen 2 de 2
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. Samsung SGH-E317 Motherboard Replacement: paso 9, imagen 1 de 2 Samsung SGH-E317 Motherboard Replacement: paso 9, imagen 2 de 2
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
Conclusión
Chris Dimler
Miembro Desde 01/22/11
124 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-23, Maness Winter 2011 Miembro de Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 15
Todo El Tiempo: 1,395
