Introducción
This guide will show you how to replace the camera in your Samsung SGH-E317 phone. This guide will fix the issue if the lens is blurry, has a broken sensor, or cannot capture photos.
Before we start, it is important to know about some problems and how to avoid them. Make sure you have the right tools and a clean, bright workspace to keep your phone safe. It is all about taking your time and not rushing.
Be careful about static electricity, which can hurt your phone's insides. In step 6, when you work with the wires, pay attention to where you align the wedge so you don't break them.
With easy-to-follow instructions and lots of pictures, even if you're new to fixing stuff, you can do it. Pretty soon, your Samsung SGH-E317 camera will be back to normal.
Before you begin, turn off your phone, and unplug it from the charger.
Qué necesitas
Remove the back panel by pressing up on switch, located at the top on the back of the phone.
Use a spudger to remove the plastic screw coverings at the base of the LCD screen.
To reassemble your device, follow these instructions in reverse order.Take your e-waste to an R2 or e-Stewards certified recycler.
