Saltar al contenido principal
Samsung SGH-A237 Logic Board Replacement
Qué necesitas
  1. Samsung SGH-A237 Logic Board Replacement, Logic Board: paso 1, imagen 1 de 2 Samsung SGH-A237 Logic Board Replacement, Logic Board: paso 1, imagen 2 de 2
    • Put the phone face down so that the battery cover is showing.
  2. Samsung SGH-A237 Logic Board Replacement: paso 2, imagen 1 de 2 Samsung SGH-A237 Logic Board Replacement: paso 2, imagen 2 de 2
    • Use your thumb to push the cover down and off.
    • Lift the battery off the device.
  3. Samsung SGH-A237 Logic Board Replacement: paso 3, imagen 1 de 2 Samsung SGH-A237 Logic Board Replacement: paso 3, imagen 2 de 2
    • Remove the five screws with a size 00 screwdriver. There 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Logic Board Replacement: paso 4, imagen 1 de 3 Samsung SGH-A237 Logic Board Replacement: paso 4, imagen 2 de 3 Samsung SGH-A237 Logic Board Replacement: paso 4, imagen 3 de 3
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Note: some force must be applied when removing back cover.
  5. Samsung SGH-A237 Logic Board Replacement: paso 5, imagen 1 de 1
    • Detach the tab from the logic board by using iPod Opening Tool (as shown).
  6. Samsung SGH-A237 Logic Board Replacement: paso 6, imagen 1 de 2 Samsung SGH-A237 Logic Board Replacement: paso 6, imagen 2 de 2
    • Use iPod Opening Tool to lift the green logic board carefully.
    • Remove logic board from the device and replace with new one.
Conclusión
Equipo
Cal Poly, Team 29-81, Johann Spring 2010 Miembro de Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 2,818
